Date: 20-04-24  Time: 05:26 am
Author Topic: Std exhaust silencer weight  (Read 3794 times)
74eldiablo
« on: 16 October 2018, 08:42:47 am »
Yesterday i took delivery of a micron shorty slip on with link pipe, having took off the original silencer i couldnt beleive how much weight was in that thing  :eek a simple test in hands was unbeleivable, so for people who still have the std can on ditch it and get another the weight savings are definately worth it.
I think the centre stand is also coming off as apart from oiling the chain it's just a big chunk off metal and reducing the weight even by a kilo or two will help with the bikes handling
redmandan
Re: Std exhaust silencer weight
« Reply #1 on: 16 October 2018, 08:48:48 pm »
Im thinking of which Winter upgrades to do this year and new exhaust is certainly in my top 3. Trouble is i would want a new stainless system up to the header and it gets pricey considering it's an old bike.
Im also in 2 minds about the sound. My standard exhaust is nice and quiet when im warming up in the mornings (respect for the neighbours is a two way street) but i would love to hear a bit more oomph going through tunnels, which the standard exhaust just does not provide.
What did you get? How much did you pay and is it excessively noisy?
YamFazFan
« Reply #2 on: 16 October 2018, 09:29:35 pm »
Would the majority of Fazer owners be that concerned about shaving off weight though?.
I'd have thought that'd be more of an issue to owners of the higher powered sports orientated machines.
« Reply #3 on: 16 October 2018, 10:53:58 pm »
The centre stand is really handy for maintenance and you won't feel any difference by removing the weight of it. You'd be get more benefit by ensuring your tyres are at the correct pressure, your brakes are clean and aren't dragging, your air filter is clean and your chain is lubed and at the right tension. Basic stuff like that. Minor weight savings won't make any difference
Millietant
« Reply #4 on: 17 October 2018, 03:58:38 am »
In my case, when the rider lost 18kg's, the bike seemed to handle, stop and go a bit better - but I kept the centre stand  :rollin
« Reply #5 on: 17 October 2018, 06:51:59 am »
I've had my bike on the Dyno machine about 3 times since i've had it, and the wizard mechanic who was working on my bike said you would never really get a better performing exhaust than the original.
I agree it's too lumpy and i couldn't stand the whiny gearbox noise to the bike so i changed it straight away anyway, but the Dyno did show up imperfections with new slip on end cans (i have a couple) and there's certainly no extra power boost in any way, even if it sounds and feels like it.
They are just a cosmetic addition to the bike that look and sound better.
I would also recommend a K&N air filter if you haven't' already got one, then do a carb balance, regardless if people say you need one or not, as it does smooth things out.
« Reply #6 on: 17 October 2018, 08:30:40 am »
:agree
K&N, and a carb balance (especially if you have changed the end can) really does make things smoother through the rev range.
YamFazFan
« Reply #7 on: 17 October 2018, 10:44:46 am »
Do they drown out that foccin great clunk going from first into second also?. If so I'm in :D .
« Reply #8 on: 18 October 2018, 10:33:48 am »
Check your chain adjustment. The FZS is very partial to having it done right. Adjusted correctly theres barely any clunk.
« Reply #9 on: 18 October 2018, 06:05:54 pm »
 :agree
My Fazer FZS600 hardly makes
 any noise, or clunk going from 1st to 2nd, but, I do get a clunk when going into first from neutral, especially when going into fist with a cold lump, I find slightly easing the bike forward with my tootsies helps to alleviate this.
Chain tension is important, this is one of the reasons you need a centre stand, spin the rear wheel by hand checking the chain tension on the lower chain run directly under the black swinging arm chain guide that is on the top at the front of swinging arm, and make sure you have 1.5 inchs of movement pushing the chain up without excessive force. I understand this is the accepted measurement for a 2003 FZS600 Foxeye.
See photo of manual.
Although I have read somewhere that the chain adjustment should be made with the motorcycle on the side stand, so that some/most of the bikes weight is on the suspension.
I have always done mine on the centre as its easier to adjust it with the rear wheel off the ground.
« Last Edit: 18 October 2018, 06:06:40 pm by tommyardin »
« Reply #10 on: 18 October 2018, 08:21:23 pm »
:agree
Would’ve thought that not only would it be awkward adjusting it on the side stand, but the tension would be too tight as well?
Even more so if you added a passenger and luggage, i reckon that adjusting it whilst on the centre stand allows for these differences?
I don’t know all this for certain, as it’s never even crossed my mind to adjust the chain on the sidestand before, but i think it makes sense.
« Reply #11 on: 18 October 2018, 11:03:24 pm »
The manual says to keep both wheels on the ground. I think the chain gets tighter when the bike is on both wheels compared to when it's on the centre stand so if you adjust the slack to the specified amount while it's on the centre stand, when you put it back down onto two wheels the chain will tighten up so it will be tighter than spec whereas if you tighten it to spec on the side stand that's where it stays. I've always adjusted it on the side stand anyway
« Reply #12 on: 18 October 2018, 11:10:38 pm »
:agree
That clunk when you knock it down from neutral into first can also be caused by worn cush drive rubbers in the rear wheel. As the rubber wears it creates a bit of free play between the rear sprocket carrier and the wheel and you feel it as a clunk. You rocking the bike forward might be taking up the gap. You can check if there's any play by grabbing the rear sprocket and rotating it clockwise and anti clockwise.
« Reply #13 on: 18 October 2018, 11:29:54 pm »
:agree
My bike has always done it, even when i put new cush drive rubbers in the wheel.
It's just a quirk of the bike, and i do the same as Tommy, just roll the bike forward a bit when changing down and it is nowhere near as harsh or noisy.
« Reply #14 on: 18 October 2018, 11:32:53 pm »
yeah mine does it too. I think it's a Yamaha thing :lol
YamFazFan
« Reply #15 on: 19 October 2018, 02:51:41 pm »
Just done some measuring....
On centre stand- 30mm chain movement at the rubber thingy.
On side stand-26mm chain movement at the same place.
« Last Edit: 19 October 2018, 03:00:54 pm by YamFazFan »
YamFazFan
« Reply #16 on: 19 October 2018, 03:44:31 pm »
Just been out for a ride around petrol fill up and it's changing gear silently now :rolleyes .
Maybe got enough slack now.
    • - Mk 1 Speed Triple
« Reply #17 on: 19 October 2018, 10:10:41 pm »
If there's a slight amount of play in the chain when the swinging arm is parallel to the ground, then there'll be plenty of free movement in any other position as it's only going to get slacker whether weight is added or removed.
« Reply #18 on: 19 October 2018, 10:30:26 pm »
If there's a slight amount of play in the chain when the swinging arm is parallel to t4he ground, then there'll be plenty of free movement in any other position as it's only going to get slacker whether weight is added or removed.
Yeah, what he said.  :lol
« Reply #19 on: 20 October 2018, 08:57:00 am »
 Think about it why does the chain need slack in the first place? It’s because you have to allow for changes in chain tension due to the up and down movement of the swing arm due to the suspension compressing and extending. The position of the front sprocket is fixed rigid to the engine and the engine is bolted into the frame so the position of the front sprocket can’t move up or down but the rear sprocket is part of the swing arm assembly so the position of the rear sprocket changes, it has to move up and down relative to the front sprocket when the swing arm moves up and down. If you look at picture 1
 Imagine that picture 1 is when both wheels are on the ground the distance on side A is equal to the distance on B. In picture 2 say you hit a bump as you're riding and the suspension compresses and the swing arm pivots up around it’s pivot point so the rear sprocket pivots up relative to the front sprocket. This means the distance on side A will get shorter and side B will get longer so the tension on side A will be less and the tension on side B will be greater. That's why you need slack in the chain.
In picture 3 when you put the bike on the centre stand you’re doing the opposite, you’re taking the weight off the rear suspension so the suspension extends and the swing arm pivots down so side A would get longer and side B would get shorter creating more tension on side A and more slack on side B. That means if you adjust the chain to have 30mm slack on side B when the bike is on the centre stand, when you put it back down onto it’s wheels and the suspension compresses and the swing arm pivots up side B will tighten up and you’ll have less than 30mm slack. YamFazFan proved that’s what happens with his measurements. On the centre stand he measured 30mm slack. When he put the bike on both wheels he measured 26mm because the weight of the bike caused the suspension to compress and the swing arm to pivot up slightly. The slack side will tighten even more when you sit on the bike because you’re compressing the suspension more and that’s causing the swing arm to pivot up more. It'll tighten more if you have a pillion. And it'll tighten more when you hit a bump in the road.
YamFazFan
« Reply #20 on: 20 October 2018, 10:47:57 am »
That's a great post. Explains it so clearly.
When I first measured I found 6mm difference, then on second measuring, having wheeled it about a bit, found 4mm difference. So I'd say the average is 5mm between being on centre stand/side stand.
« Reply #21 on: 20 October 2018, 10:51:56 am »
You realize we're talking about 4mm difference here.  :lol
I would personally guarantee that if every foccer was to show how they do their own chain measuring techniques the results would have a vast difference among every bike.
They'll either be too tight, too slack, misaligned, chain too dry, or not lubed correctly on every link, etc.
What i've noticed over the years is that if a chain is misaligned, too tight, or too slack then your hearing should suss it out first.
Too slack and the chain will slap about, too tight and it will just be noisy plus you'll feel it grinding through your left foot peg.
If the chain is misaligned then a knocking/rotational grinding will be felt and heard as well.
When adjusting the chain, once the wheel nut is properly tightened up a simple spin of the wheel (on the centre stand of course) can reveal all of these traits quite easily.
If all is well then the chain will purr when the wheel is spun forwards or backwards, to the point that you just know that it's right.
There is a large amount of common sense involved here, as well as what is advised in the manual.
« Reply #22 on: 20 October 2018, 11:08:09 am »
Pictures 2 & 3 are the same, just the reverse of each other.
I think irrespective of how you check your chain slack, whether on centre or side stand, once you know what feels right you'll know what to do next time anyway.
I don't even measure any more, i started using the "Unfazed" way by pushing the chain up until it just hits the chain slide. It seems to be adequate enough.
And don't forget the manual suggests 30-45mm play on my bike so it's not that critical. It's the sound effects that play more an important role for me.
« Reply #23 on: 20 October 2018, 11:29:48 am »
Of course it's a mirror image because the swing arm pivots around the same point whether it's pivoting up or down so the effect is the same just on opposite sides of the chain.
Say YamFazman found that it's a 5mm difference just from the weight of the bike. 5mm difference when the spec is 30mm-45mm that's 11% to 17% difference just from the weight of the bike. Sit a 100kg rider on the bike and the slack side will tighten more probably another few mm. Sit a 60kg pillion on and it'll tighten more, then add in hitting bumps and it tightens more. It would be made even worse if your chain was a bit old and had a tight spot in it. Does adjusting it on the centre stand make such a huge difference that it causes major problems? It seems not based on the fact that some people adjust it on the centre stand and get away with it but the point that I'm try to explain is that is it does make a difference. They give you the 30mm-45mm spec for when both wheels are on the ground so if you're using the 30mm-45mm as your guide you have to have both wheels on the ground to get the right amount of slack. Saying that adjusting it on the centre stand makes no difference isn't correct
« Reply #24 on: 20 October 2018, 11:38:57 am »
Like you said most people probably adjust it by eye, give it a wiggle up and down and call it good because they know from experience what to expect. That's totally different from taking a measurement. All I'm saying is if you're doing it by the measurement method having the bike on the centre stand or on the ground does make a difference.
