Date: 26-04-24  Time: 17:47 pm
Author Topic: Chain tension  (Read 1340 times)
Gazza
      FZ6 S2 07-09
Chain tension
« on: 29 August 2018, 09:39:40 pm »
Just fitted new chain and sprockets , just checking chain tension , got it too 30mm movement is that about right , bandit before Fazer was 25 to 30 mm , not got a manual yet ,thanks .
      FZ6 04-06
    • Affordable Leather Products
Re: Chain tension
« Reply #1 on: 30 August 2018, 11:07:51 am »
I have the FZ6-SA (the version before yours) and the recommended chain tension was 45-55mm (doesn't matter if it's on the side stand or centre stand). According to the Haynes Manual, it's the same for the S2, so 30mm is too tight.
A quick and dirty check I found is to try to push the chain up against the swing arm about 3 or 4 inches behind the foot peg. If it just taps against the swingarm but you have to keep pushing it to hold it there, the tension should be about right. If you can't get it to touch or it it's very easy to hold it there, it's too tight or loose respectively.
agricola
  • Man on a mission
      FZ6 S2 07-09
Re: Chain tension
« Reply #2 on: 30 August 2018, 06:08:07 pm »
45mm to 55mm for the S2 Fazer
Gazza
      FZ6 S2 07-09
Re: Chain tension
« Reply #3 on: 30 August 2018, 10:39:54 pm »
Thanks I took your advice and changed it to 48mm tonight before going for a quick ride ,glad I did , it runs so much quieter now , thanks again for the reply s .
