Date: 25-04-24  Time: 10:44 am
Author Topic: I have got a stiff one  (Read 1125 times)
« on: 21 July 2018, 12:42:38 pm »
Chain link that is.I can feel it and hear it when the chain is under a low load at about 40mph, not coasting nor can I feel it under any decent load.I am not quite ready for a new chain and sprocket set so what is my best course of action-- slacken off wheel and set to work on the misbehaving link with two pairs of pliers and some engine oil ?.I did previously tighten the chain a tiny fraction so 95% of the chain positions would just touch the guide but then there is that one tight spot with the stiff link that is a little too tight. Should I adjust the chain to that one tight area and have the rest perhaps a little too slack like all the guides actually tell you to do  :lol :deal .
Re: I have got a stiff one
« Reply #1 on: 21 July 2018, 03:47:19 pm »
Is this the original chain?
agricola
  • Man on a mission
      FZ6 S2 07-09
« Reply #2 on: 21 July 2018, 06:17:23 pm »
Is it the rivet link thats tight. If it is, id be inclined to replace it. If not, try working at it
« Reply #3 on: 21 July 2018, 06:22:50 pm »
Yes -20k miles - I know its getting ready for a new set but the sprockets still look ok to me.
I have just been all round the chain slackened it right off to start and checked each one and there are more stiff ones than I thought - not super stiff but not so loose so that I can bend the links with my fingers if you know what I mean none were that bad but they all feel free now. But I still have a tight spot in the chain, must have an oval rear sprocket.
I did check the alignment with the two lines method a few months back and found the swingarm markings to be correct.
Going out now for a test ride
« Reply #4 on: 21 July 2018, 06:23:55 pm »
its the OEM chain from new so don't think it has one
« Reply #5 on: 21 July 2018, 07:51:36 pm »
Correction - its done 21600mls.Well the test ride showed a small improvement but still there at 40 mph 4k revs in 4the gear and 3k revs at 40 in 5th but only if I hold at that speed. I don't feel anything upto or over 40.
Now here's the reason I do not like scot oilers after using engine oil to work into the links
« Last Edit: 21 July 2018, 07:52:45 pm by fazersharp »
« Reply #6 on: 21 July 2018, 09:07:26 pm »
I doubt very much it will improve in my humble opinion, and 20 years out of a chain and sprockets ain't too bad.
Maybe you can save up and buy it a new kit for Xmas.  :lol
« Reply #7 on: 21 July 2018, 09:38:24 pm »
I get the yearage but not the mileage. Still don't get how a chain and sprocket set can wear so that you end up with a tight spot, all links are now free of tight links in themselves and yet I have a tight spot that I can feel passing over the sprocket or under it.
Its not the money so much as the time because I will be using a continuous chain so that is -- swing arm off but at least that gives me an opportunity to re grease all linkages but while the sun is shining ----- :faz :woot
VNA - BMW Wank
  • BMW Wank
    • - BMW R1250R Honda C90
« Reply #8 on: 21 July 2018, 09:52:44 pm »
Just fit a split link chain.  Save you taking the swing arm out.
And fit a Scottoiler - saves you getting tight spots.  :D
