Date: 20-04-24  Time: 01:59 am
Author Topic: Snapped exup housing bolts  (Read 1145 times)
Kenbob
« on: 17 July 2018, 12:41:10 pm »
hi all.
Well I’ve managed to snap the heads off of  a couple of my exup housing bolts and most of the thread is left in the housing.
For those who have been there or who know what I need to do now, what do I do now, help!!!! :'(
ogri48
    • - XJR1300 , evo fatty
Re: Snapped exup housing bolts
« Reply #1 on: 17 July 2018, 01:24:43 pm »
Patience, heat, decent drill bit, easy-out,decent tap to clean up thread...it'll be fine mate. All doable in situ and If you can't get the stainless replacement ALLEN caps I've got spares, I'll send you a set. 👍😉 btw if your anywhere near the Forest of Dean fetch it over I'll give you a hand
« Last Edit: 17 July 2018, 01:28:19 pm by ogri48 »
Kenbob
« Reply #2 on: 17 July 2018, 01:37:46 pm »
Thanks for the offer but I’m in croydon surrey.
Do you know the right tap size perchance and I’ve just been looking at the easy out bits.
I also have the stainless replacement bolts but thanks anyway.
ogri48
« Reply #3 on: 17 July 2018, 01:44:19 pm »
With mine mate I actually ended up not useing easy outs. I drilled the bolts out slightly smaller than the original bolt so all that was left was the bolt thread, and slowly kept at it with a tap covered in grease, (m6 I think) in out in out half a turn at a time until it was. Cleaned out and on the original threads. Takes ages, but satisfying, in a weird way lol
« Last Edit: 17 July 2018, 01:45:08 pm by ogri48 »
Kenbob
« Reply #4 on: 17 July 2018, 03:14:26 pm »
Will give that a go but might try the easy outs first.
5LV
« Reply #5 on: 17 July 2018, 05:36:09 pm »
Buy a 4/5mm drill from an engineering shop. (Forest Fastners eh ogri)
Nice and slowly does it, then either retap or easy out the old bolts. Stainless bolts and coppaslip. Loosen them once a year and no more problems.
ogri48
« Reply #6 on: 17 July 2018, 07:49:19 pm »
Lol yeah buddy Forest fasteners got the lot, handy place indeedy...👍👍
Kenbob
« Reply #7 on: 17 July 2018, 08:20:06 pm »
Cheers, will look them up.
Hugh Mungus
« Reply #8 on: 17 July 2018, 09:37:09 pm »
The most important thing is not to use cheap drill bits. Get the best you can afford, it will make the job so much easier.
I drilled mine out with a 5mm bit and then re-tapped with an M6. I took my time (for a change) and it all went to plan.
Kenbob
« Reply #9 on: 18 July 2018, 04:02:29 pm »
Just throwing this in here to see if anyone has tried the helicoil method, tap v helicoil, which one is better or easier even.
Hugh Mungus
« Reply #10 on: 18 July 2018, 04:50:57 pm »
If you can drill and re-tap I would go down that route. If the re-tap doesn't work you can then do a helicoil.
