Date: 25-04-24  Time: 08:31 am
Author Topic: LED Flashers  (Read 3298 times)
Geedog
LED Flashers
« on: 03 July 2018, 03:45:08 pm »
Hi all
So I’ve got some LED flashers on the bike now and swapped the old flasher relay or an LED one...can anyone enlighten me as to why they dont flash? They just light up once and stay on....do I need inline resistors too?
Help?!
TIA
Aaron
Re: LED Flashers
« Reply #1 on: 03 July 2018, 03:47:45 pm »
Sounds like you have a dodgy relay. Is this with the engine running as well as when its off?
If you put the original one back in do they flash too fast? The LED's may already have resistors fitted making the resistance too high so you would need to go back to the standard relay if they flash normally with the standard relay
« Last Edit: 03 July 2018, 03:48:37 pm by BBROWN1664 »
Geedog
Re: LED Flashers
« Reply #2 on: 03 July 2018, 03:59:28 pm »
They flash with the original but too fast and not all of the LEDs light up..
With the new relay they all light up but dont ‘blink’ with the bike running or off.
They dont pear to have any resistors fitted to them..
Re: LED Flashers
« Reply #3 on: 03 July 2018, 04:08:28 pm »
sounds like a dodgy relay
Hugh Mungus
Re: LED Flashers
« Reply #4 on: 04 July 2018, 05:01:10 am »
I reckon it's a dodgy relay too.
The original one is doing what is expected when you put LED indicators on. Not all the LEDs are lighting up because it's going too fast so don't worry about that part.
Geedog
Re: LED Flashers
« Reply #5 on: 04 July 2018, 11:58:23 am »
If I were to ut the original relay back on and use in line resistors would/should that work?
Re: LED Flashers
« Reply #6 on: 04 July 2018, 02:21:58 pm »
yes, but its a bodge. Just order a new relay.
Hugh Mungus
Re: LED Flashers
« Reply #7 on: 04 July 2018, 07:59:07 pm »
The in-line resistors are easy to fit. They're not really a bodge as they are simply increasing the resistance load to match what ordinary bulbs would be - some LED indicators have them built in.
Buying and fitting one relay is easier though.
Geedog
Re: LED Flashers
« Reply #8 on: 12 July 2018, 12:21:00 pm »
It seems I now have a relay that works...but when the bike is running anything more than an idle the flashers speed up to match...do I need to fit those resistors still then?
Re: LED Flashers
« Reply #9 on: 12 July 2018, 01:23:20 pm »
How fast are they flashing at idle/off and how fast at say 5K?
Geedog
Re: LED Flashers
« Reply #10 on: 12 July 2018, 03:33:20 pm »
At idle they flash at the speed you would expect them to, about 60-70 per minute, as the Revs increase, so does the speed of flashing so at 2000 they are about twice as fast, at 5000 they flash at about 200x per minute...
Re: LED Flashers
« Reply #11 on: 12 July 2018, 04:13:41 pm »
Check your battery voltage at those speeds. I suspect you may have a problem with your rectifier.
Geedog
Re: LED Flashers
« Reply #12 on: 25 July 2018, 10:43:41 am »
Apologies for the radio silence...anyway, I checked the voltage on battery idling is 12 point something, when revving up to about 4-5k voltage goes up to 13.5 ish...is that normal?
Re: LED Flashers
« Reply #13 on: 25 July 2018, 01:54:13 pm »
sounds a little low
Hugh Mungus
Re: LED Flashers
« Reply #14 on: 26 July 2018, 05:15:18 pm »
I would need to be there in person to make a proper judgement but at first glance of your figures I'd agree with BBrown1664 in that it looks a little low. Not massively low, just a bit. This can be causing you a few problems. Before I go suggesting things that might be expensive...
Did the original indicators work properly or did you have problems with those too?
Geedog
Re: LED Flashers
« Reply #15 on: 27 July 2018, 09:28:48 am »
No, originals were fine, no problems with them
Geedog
Re: LED Flashers
« Reply #16 on: 27 July 2018, 09:33:57 am »
One thing I haven’t mentioned is that the new LED lights are the ‘flowing’ type indicators, (12 LEDs on each)
Hugh Mungus
Re: LED Flashers
« Reply #17 on: 27 July 2018, 03:20:42 pm »
I've got those on mine. I fitted an adjustable flasher relay as I got some cheap. I haven't used in-line resistors as I didn't need any because the relay has sorted that out.
I get no difference in flash rate with engine running or not.
As your original indicators worked fine I suspect that it is still the relay.
What parts have you actually fitted to the bike?
Geedog
Re: LED Flashers
« Reply #18 on: 30 July 2018, 04:09:11 pm »
Are you asking what brand or what part? I have fitted new relay x2, first from amazon didn’t work, 2nd one from eBay did but with the current problem...what have you used and where can I source from?
Hugh Mungus
Re: LED Flashers
« Reply #19 on: 30 July 2018, 06:04:09 pm »
I bought 5 of these - the first one I fitted didn't work but the 2nd one did.
https://www.ebay.co.uk/itm/2-Pin-Speed-Adjustable-LED-Indicator-Flasher-Relay-Resistor-Fix-Motorcycle-uk/153051351844?hash=item23a2924b24%3Ag%3AJ5UAAOSwJLJZg-Af&_sacat=0&_nkw=+2-Pin-Speed-Adjustable-LED-Indicator-Flasher-Relay-Resistor-Fix-Motorcycle-uk+&_from=R40&rt=nc&_trksid=m570.l1313
I didn't mind waiting a month for them to arrive, you can get them quicker from a UK seller but they will cost more.
« Last Edit: 30 July 2018, 08:46:43 pm by BBROWN1664 »
Geedog
Re: LED Flashers
« Reply #20 on: 30 July 2018, 09:25:29 pm »
I may struggle with my extremely limited knowledge with electrics, to fit this as it isn’t the same pins to plug in..any tips?
Hugh Mungus
Re: LED Flashers
« Reply #21 on: 30 July 2018, 10:07:41 pm »
Oh yeah. I made up 2 wires - one end fitted with a male spade end connector and the other end with a female spade end connector. Both wires the same to make an 'extension cable'. Only needs to be a few inches long. Doesn't matter which way around you connect to the relay.
Geedog
Re: LED Flashers
« Reply #22 on: 30 July 2018, 10:20:15 pm »
Cheers pal, I’ll give i a try
Geedog
Re: LED Flashers
« Reply #23 on: 02 August 2018, 10:54:28 pm »
Adjustable flasher relay arrived and I doctored up some leads to fit..seems to work so far..flash rate is constant up to 4K revs while bike in neutral so i cant see why that would change once on the road..fingers crossed! Thanks for the tips all
Az
Hugh Mungus
Re: LED Flashers
« Reply #24 on: 03 August 2018, 06:03:24 am »
Great. Will keep fingers crossed...
