The LCD displays on the clocks of my FZ6 are flickering and I think it's due to dirty/ corroded contacts on the connector plugs that go from the ECU, past the yokes and into the bottom of the instruments.
There is a plug (see image) that I want to disconnect to clean the contacts, but it seems to have *three* clips, one on the top and one on each side.
This makes it impossible to get apart (at least as far as I have managed!)
I tried wedging thin screwdrivers down each side to separate the clips , then using another to undo the clip on the tip, but it won't budge.
Am I doing something wrong or is it just a total bugger??
