Date: 24-04-24  Time: 19:57 pm
Author Topic: *SOLD*- Pair of Kappa Rear Hard Case Panniers and mounts for 1998-2003 FZS600  (Read 1027 times)
hopefiendboy
  • Second time Fazer owner- back to the womb
    • Main bike:
      FZS600 00-01
    • - none
    • View Profile
Hi
Finally got my new bike!!! Yay! It came with some hard luggage and mounts which I will not need so putting these up for sale to fund general maintenance and suspension mods.
Genuine KAPPA left and right hard case panniers along with all mounts. The brackets show points of surface rusting in places but a quick rub down and spray would do the job- they are not heavily corroded. The system is very neat and mounts/dismounts in a very slick fashion-I was impressed. Both cases are lockable and come with 2 spare keys matching lock barrels (ie same key does both cases). Take up to 10KG max each according to the label. If I have time I will prep these brackets etc so that the rust is treated.
The previous owner also had the top box, the bracket mount has fixings for a plate for this but this has been lost/misplaced, but means in future you could add to this set up.
£80 pounds, a bit more for postage. Based in Edinburgh.
« Last Edit: 03 May 2018, 02:59:47 pm by hopefiendboy »
hopefiendboy
    • Main bike:
      FZS600 00-01
    • - none
    • View Profile
