Date: 29-03-24  Time: 00:48 am
Author Topic: black plastic fork cover  (Read 850 times)
mobile mouse
« on: 17 April 2018, 09:30:08 pm »
I need to remove the black fork cover from the top of the lower fork.
Are they easy do i rotate it and pull or what.
I don't want to damage the Alu or the fork cover...
Re: black plastic fork cover
« Reply #1 on: 17 April 2018, 10:22:50 pm »
The fork cover clips into a recess on the lower fork leg (search for pic of lower fork leg) try using your fingers to push it up or wrap something around the lower leg & carefully use a small screwdriver.
You don't need to remove them for any fork work ie fork seal replacement.
mobile mouse
« Reply #2 on: 17 April 2018, 11:23:25 pm »
the lower fork legs are going to be vapour blasted to clean them up so they need to be striped.
« Reply #3 on: 17 April 2018, 11:40:01 pm »
Hiya excuse a silly question but what is vapour blasting, sand, grit and bead I understand but vapour blasting???? Is it a sort of steam clean?
    • disorderly punks motovlog
« Reply #4 on: 18 April 2018, 08:28:04 am »
its high pressure water with grit in
its a softer approach than typical sandblasting and often better as it gives a smoother more uniform finish
so many people have carbs done this way but i am not a fan as the grit is not soluble and gets everywhere
stripped engines with big holes are fine and can be flushed but carbs should be soda blasted
(just for future refference that last bit - and im looking into starting a soda blasting/ultrasonic service when i get to preston lol)
mobile mouse
« Reply #5 on: 18 April 2018, 09:29:56 pm »
