Date:
25-04-24
Time:
05:06 am
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Forum
Basics
FAQ
Tips and Tricks
SMF's help
About
Links
Articles
Fazer1000/FZ1
FZ8
FZ6
FZS600
For any bike
Misc
Media
Downloads
Fazer 1000/FZ1 corner
Winter maintenance time
« previous
next »
Print
Pages:
Author
Topic: Winter maintenance time (Read 8067 times)
GP Hero
Never ride faster than your guardian angel can fly
Main bike:
- FZS1000 05-06, Serow 2000
Re: Winter maintenance time
Reply #25 on:
14 January 2018, 09:50:40 am »
Of course, but you need to add a bit of pipe to the adjuster to give a better bang.
Logged
Mustang
Club Racer
Main bike:
- MT-09 2015
Reply #26 on:
15 January 2018, 10:12:23 pm »
Cleaned up the water pipe splitter that sits under the frame, lot of corrosion around the open ends, spun this off with a wire wheel in the drill, got a couple of pinholes now. Used some steelseal to coat the ends up and build up the thin metal. Then a coat of satin black.
I'm still waiting for the shims to turn up so there's not much I can do. I've coated the new gaskets with sealant and stuck them onto one side of the covers, syphoned out the expansion tank, ordered some moly grease and coolant.
Logged
kgjersda
Weekend Warrior
Main bike:
Reply #27 on:
16 January 2018, 09:51:32 am »
Wrong forum, thought this was FZS600...
These were mine at 56000km/34800miles:
I left them alone, but I see now that I should probably swap them next time around...
Last Edit: 16 January 2018, 09:52:39 am by kgjersda
Logged
Mustang
Club Racer
Main bike:
- MT-09 2015
Reply #28 on:
19 January 2018, 04:45:54 pm »
Valves clearances all adjusted and rechecked, shims turned up yesterday.
Mostly in the midrange a couple at the top end as I can't measure the shims right sometimes.
Covers back on and top end water system all painted up and refitted.
Next job, dropped the exhaust off so I can clean up and paint the motor. Might have to get another water pipe o ring though as the lower pipe is fitted same as the top ones.
Feeling pretty pleased the exhaust nuts spun off ok, they are sitting in some harpic now to clean up.
Last Edit: 19 January 2018, 04:47:00 pm by Mustang
Logged
Mustang
Club Racer
Main bike:
- MT-09 2015
Reply #29 on:
19 January 2018, 04:47:42 pm »
Next job
Logged
agricola
GP Hero
Man on a mission
Main bike:
FZ6 S2 07-09
Reply #30 on:
19 January 2018, 09:24:00 pm »
Im sure you would have done, but shove some rags in those 4 holes to stop shite going in
Logged
Mustang
Club Racer
Main bike:
- MT-09 2015
Reply #31 on:
25 January 2018, 05:33:44 pm »
Well after 7 days of flu including 3 bedridden, I managed a bit more today.
Gave the front on the engine a scrubbing with paraffin then some brake cleaner prior to thinking about painting. I'm concerned as there is still a lot of stuff in the way, oil cooler, oil filter, engine mounts. Do I just mask off as much as poss?
Took the exup valve out and greased it all up. I think it wasn't seated right before as it would not rest over the locking hole but now I've had it all out I've made it fit. This does rotate clockwise from closed doesn't it? Looking at the pulley side that is.
Gave the rest of the down pipes a real clean with harpic and emery cloth, exhaust gaskets pried out, can I reuse them? That's it for now.
Last Edit: 25 January 2018, 05:34:30 pm by Mustang
Logged
sirgalahad3
Club Racer
Main bike:
- SR 500
Reply #32 on:
25 January 2018, 06:26:11 pm »
When I did the front of my engine I took everything off, oil cooler, filter, pipes out of the engine, everything then just masked up the frame. Seemed the best and easiest way and it worked well
Logged
Mustang
Club Racer
Main bike:
- MT-09 2015
Reply #33 on:
26 January 2018, 04:18:01 pm »
Took off the oil cooler and water pipes, bad corrosion on the oil cooler water pipes, pinholes. So out comes the chemical metal again. This bikes been run for some time with just water in there and it's taken its toll. I'm gonna have to flush it and maybe try some rad flush as well. Gave the bits a coat of paint now it's down to making the motor off and spraying it up.
Logged
Mustang
Club Racer
Main bike:
- MT-09 2015
Reply #34 on:
29 January 2018, 07:27:02 pm »
Well it's done, apart from the carbs but I had to reassemble and test the oil n water tightness.
Sprayed up the motor in the frame but it was a bit cold so parts had to be done again with a heater on them. Had a couple of small leaks on the cooler pipes which were a bit of a pig to get to with the down pipes back on but it seems ok now, just running it with soft water for now to check its all sound and after a road test I'll swop it for coolant.
Logged
Mustang
Club Racer
Main bike:
- MT-09 2015
Reply #35 on:
29 January 2018, 07:29:12 pm »
Looks better
Logged
cl1ve2004
Weekend Warrior
Main bike:
- vstrom 650 al8
Reply #36 on:
29 January 2018, 08:39:36 pm »
nice job there...
Logged
GP Hero
Main bike:
- Mk 1 Speed Triple
Reply #37 on:
29 January 2018, 09:07:54 pm »
Sweeeet
Logged
Mustang
Club Racer
Main bike:
- MT-09 2015
Reply #38 on:
05 February 2018, 04:30:10 pm »
Put fresh coolant in it and thats as far as Ive got at the moment. Bikes all back together, not started the carbs yet, struggling a little with motivation and its bloody cold too. Thinking about a Ivans jet kit while the carbs are out - anyone selling one?
Logged
Flooky
Weekend Warrior
Main bike:
Reply #39 on:
06 February 2018, 07:08:32 am »
Great job, nice thread, cheers
Logged
Print
Pages:
« previous
next »
SMF 2.0.18
SMF © 2011
Simple Machines
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
