The price the supplier Dusty used is not too bad. £9.99 for a Gen 1 Fazer key. Depending on their packaging, first class signed for is £1.75 for a small letter, £2.08 for a large letter so basically it's £8.00 for the key.Cutting from a photo is simple enough if the trader has the required software & hardware. Also, knowing which vehicle the key is for is a head start.Of course, a key can even be made by hand!This leads to being aware that leaving (any of) your keys on the bar, shop counter, etc. unattended or unwatched is a real no-no these days as a thief only needs a decent photo of your key to make their own & help themselves to your bike, house contents, whatever!There is evan a mobile phone app. which will scale the key for you.Caution is also advisable when using any postal method as the there party by default will know where your house & bike, etc. are located!As a price guide...Part of my business is key cutting (though I only cut from your key). My Fazer 1 keys are £4.00. Places like Timpsons are about £7.00-£8.00.Yamaha barrels are renowned for being fiddly as they are on top of the yolk so prone to moisture ingress. I spray GT-85 into mine regularly which helps a lot!
So what about when you order luggage, bike parts etc ?The seller still has your personal details and knows you've got a bike.Maybe you shouldn't be buying anything online if you're that paranoid.
Like I said............... PARANOIA ...................!!
Might just be worth taking a high quality photograph of your key something like this, and yes it is my bike key, but alas it only fits the fuel tank and the seat as the ignition lock was replaced 4 or 5 years ago, so if you want to come around after dark you can fill the bike up with fuel for me or check the battery.
Quote from: tommyardin on 16 December 2017, 11:19:07 pmMight just be worth taking a high quality photograph of your key something like this, and yes it is my bike key, but alas it only fits the fuel tank and the seat as the ignition lock was replaced 4 or 5 years ago, so if you want to come around after dark you can fill the bike up with fuel for me or check the battery. Have you got a full tank of fuel and how old is your battery? I need both
DECOKE DAVE..........just curious - bearing in mind that you can just go to your local key cutter when you have 5 mins. spare & get a couple of spares cut!....job done! (Go to an independent & you'll save a few quid.) - why the strong desire to find your barrel number?Sorry your thread got a bit hijacked btw! Tommy is quite right IMO, nothing wrong with being cautious & looking out for what you've worked & saved for! It's a matter of balance, there is a big difference in ordering products & actually giving someone access to your key.
DECOKE DAVE..........just curious - why the strong desire to find your barrel number?
Quote from: Andy W on 18 December 2017, 09:55:21 amDECOKE DAVE..........just curious - why the strong desire to find your barrel number?Because one cut from a key code is better than copying a worn key - although it has never caused me any problems in the past. I've got to admit that if I only get one key with the bike I always get a copy made within the first week.
