i think darrsi has hit nail on the head there
if you have a clogged air filter you increase negative pressure in the carb and you will pull more fuel through (pressure has to equilise somehow)
you are effectively running rich and using more fuel per mile and not enough air to give you the power when you need it as the stoichiometric efficiency is well off
