Date: 24-04-24  Time: 18:44 pm
Author Topic: Tachometer is nuts  (Read 3389 times)
Jimmy2wheels
Tachometer is nuts
« on: 29 August 2017, 09:55:05 am »
My speedo was broken, so I managed to fix that, but now my tachometer goes up, then down, then the correct reading. I understand this is tell me there's a fault, and I guess it's a fault with the sensor as I've replaced the speed sensor and that's now working fine.
I've got a multimeter. What should I be testing and looking out for on the rev counter sensor?
Any help or link to info would be appreciated.
    • disorderly punks motovlog
Re: Tachometer is nuts
« Reply #1 on: 29 August 2017, 10:01:13 am »
what number does it go up to
- its a fault code warning
Jimmy2wheels
« Reply #2 on: 29 August 2017, 11:30:04 am »
I can't remember off hand. Let me have a look tonight and I'll get back to you. Cheers
pointer2null
  • Ye canna' change the laws of physics!
    • - NC750X
« Reply #3 on: 29 August 2017, 08:59:32 pm »
TPS sensor misaligned.
pointer2null
    • - NC750X
« Reply #4 on: 29 August 2017, 09:02:00 pm »
Jimmy2wheels
« Reply #5 on: 30 August 2017, 09:42:15 am »
Jimmy2wheels
« Reply #6 on: 30 August 2017, 09:43:10 am »
It moves from 0 to 3k then to idle, repeatedly.
« Reply #7 on: 30 August 2017, 01:35:19 pm »
3000 is a code for a totally fooked, or unplugged TPS.
« Reply #8 on: 30 August 2017, 01:53:21 pm »
yep TPS on right hand side of the carbs
make sure it is all plugged in and contacts are clean (including under tank if there is another plug to the main loom)
i forget to plug mine in everytime i have the carbs off and think WTF for a second
Jimmy2wheels
« Reply #9 on: 30 August 2017, 03:18:07 pm »
Ahhh...
I have unplugged it, then. Ack it and it didn't make a difference. Maybe I'll check the other end tonight. And ideas of the cost of a new one?
pointer2null
    • - NC750X
« Reply #10 on: 30 August 2017, 03:20:31 pm »
Check the connections are clean and tight and that the plug is fully inserted. Check the other end of the wire to make sure you didn't disturm that as well. Try loosening the screws and moving it a abit (it's basically a potentiometer - volume control) so a wiggle won't hurt.
Jimmy2wheels
« Reply #11 on: 31 August 2017, 07:58:49 am »
Right. I tested the TPS with a multimeter as per Haynes manual and got nothing. Then I found this http://bikesandtravels.com/biker.aspx?ride=201
Seems interesting. Anybody know where I could buy a cheap TPS?
« Reply #12 on: 31 August 2017, 09:54:37 am »
Ebay "FZS 600 Throttle Position Sensor"
DO NOT buy a used one!
« Last Edit: 31 August 2017, 09:55:26 am by darrsi »
« Reply #13 on: 31 August 2017, 01:10:02 pm »
Has anyone taken the cover off a dead tps? Is it just a circuit board with a wiper arm or is there more going on in there?
Jimmy2wheels
« Reply #14 on: 31 August 2017, 01:44:35 pm »
As my fazer is a carb model. How does this faulty TPS affect the bike? Will it make a difference to the handling? I think my carbs need ballancing, but I'm not sure it's related to the sensor.
« Reply #15 on: 31 August 2017, 02:05:09 pm »
A faulty or knackered TPS will make the bike idle roughly, be very jerky under 3000rpm with the need to really use a lot of clutch to control things, and the bike will generally run a bit shite.
Even when the TPS was not in the correct position i learned to realise the difference in feel of the bike.
You need to check the TPS positioning before and after a carb balance so if you think it's faulty don't even go near the carbs yet.
Also, when contemplating a carb balance, you need a clean/unclogged air filter as well for best results.
crickleymal
« Reply #16 on: 31 August 2017, 04:24:10 pm »
Pretty much. I saw one that someone had repaired somewhere..... here it is
http://diversionclub.proboards.com/thread/24080/tps
Malc
Old enough to know better.
Jimmy2wheels
« Reply #17 on: 31 August 2017, 04:52:03 pm »
http:/ersionclub.proboards.com/thread/24080/tps
That was interesting. I'll have a look at that tonight. Worth a shot.
« Reply #18 on: 31 August 2017, 04:53:26 pm »
Just looked at that link, i really don't know how they say the TPS makes no difference to the running of the bike, because i can say through experience that if it ain't right then the bike runs like a complete pig, hence the reason i always knew when they were on their way out?
Add to that, if it wasn't there to do a job then it wouldn't be there at all.
There's a big difference in smooth running once a faulty one has been replaced with a fully functioning unit.
« Last Edit: 31 August 2017, 04:53:58 pm by darrsi »
« Reply #19 on: 31 August 2017, 05:49:29 pm »
hopefully no one will shoot me for this
but i believe the ignition timing is either advanced or retarded slightly when there is no/little throttle
there is a reason we have ignition modules nowadays and dont just run points like the good old days
(the good old days - im only 34 FFS)
Jimmy2wheels
« Reply #20 on: 31 August 2017, 06:57:09 pm »
Ok. I've taken it apart. The spades are not broken like the link on the other website, but it didn't look right. I'd upload a pic if I knew how...
Jimmy2wheels
« Reply #21 on: 31 August 2017, 07:15:47 pm »
I know. I've put it on my Instagram. Can you guys tell me if it's knackered...
Any ideas how to fix it?
https://instagram.com/p/BYd8PqhgF7N/
« Reply #22 on: 31 August 2017, 07:36:15 pm »
I fixed mine by buying a new one.  :lol
