Date: 07-05-24  Time: 09:29 am
Author Topic: 1998 fazer 600  (Read 4040 times)
Waterhouse
1998 fazer 600
« on: 21 August 2017, 09:15:46 pm »
Hello all I'm new to the forum. I have my mod 2 test coming up soon and am thinking of a fazer 600. I've seen one I like locally. It's the 1998 600 in red I'm just wondering what kind of price I should be looking at. It says it's only 1700 miles and been sat for 16 years new battery and starts and runs fine. Will it need coolant oil tyres fork seals or anything else changing ? As I say fairly new to biking and fazers. So all advice welcome[/size]Thanks.
Bretty
Re: 1998 fazer 600
« Reply #1 on: 21 August 2017, 10:21:08 pm »
An excellent choice for a first big bike!
Got any photos?
Sat for 16yrs, hmm, it depends how it's been stored. If indoors and sheltered from the elements, it'll probably be in good nick. If stored outside obvious signs of corrosion and perished rubber would be the main thing to look for. Common issue is for the rubbers between the carbs and the engine (edited: not airbox) to crack, but it takes a lot for them to go right through.
If it's noticeably rusty I would be worried about pitting on the forks, rusty exhaust studs, the exhaust itself (the original is prone to corrosion) and chain. And the clutch might be a bit sticky if the plates have corroded.
To be fair, nothing on a Fazer is massively expensive to put right, with the exception of the gearbox, front sprocket nut and exhaust studs. All common issues with a fazer but shouldn't be a concern on a low mileage bike like that.
« Last Edit: 22 August 2017, 04:58:09 pm by Bretty »
-suck-squeeze-bang-blow-
Re: 1998 fazer 600
« Reply #2 on: 21 August 2017, 10:22:03 pm »
Welcome fella - great choice of bike.
Reckon you'll be looking at new tyres @ £200 tops for Michelin PR3's, a full service and a carb clean for starters. Budget around £450. Amy link to the advertised bike so we can offer more advice ? You could find a better bike that's been used more for less money which is a better buy.
Bretty
Re: 1998 fazer 600
« Reply #3 on: 21 August 2017, 10:25:05 pm »
Price wise. You can buy a ropey old high mileage fazer for around £800. An immaculate bike with that sort of low mileage could fetch double that.
limax2
  • Creep.
Re: 1998 fazer 600
« Reply #4 on: 21 August 2017, 10:25:30 pm »
Welcome to the site Waterhouse.
Such a low mileage for a 1998 bike is pretty unique so I am sure I have seen the advert. The price at nearly £2,000 is about double what you would normally expect to pay for one in good condition of that age, but as said the mileage makes it unique. The advert says it has the original tyres so at nearly twenty years old you don't want to be riding on them. Unless you know the oil and coolant has been recently changed then that needs doing along with the oil filter. Also change all the brake fluid and the fork oil as well. If it runs ok I would then just use it and not worry about the forkseals unless they start to leak.
The price might be high for the year but you will never get another with such low miles at any price.
If I had more room and less bikes it would have already been sold to me 😃
« Last Edit: 21 August 2017, 10:28:41 pm by limax2 »
Waterhouse
Re: 1998 fazer 600
« Reply #5 on: 22 August 2017, 03:53:04 am »
Thanks guys. Yeah I'm aware of the rarity of one with that low mileage if it's genuine which it does seem to be. Yeah I was think 2k a lot but on the other hand could be a steal if it is as good as he claims. It's advertised as a barn find and rare opportunity so I'm guessing it's been sheltered from the elements and it does look very clean.
Waterhouse
Re: 1998 fazer 600
« Reply #6 on: 22 August 2017, 05:26:06 am »
Re: 1998 fazer 600
« Reply #7 on: 22 August 2017, 06:56:11 am »
 :agree
It's a tough one, as the bike certainly does look in very good nick, but as mentioned in reality the price is a bit too much because of the year but i s'pose that should really apply to a used bike of this year, whereas this one hasn't been used.
There are 125's that are selling for way more than this sort of money but you're getting much more bike with a Fazer so in that respect i think it's worth it, BUT, as also mentioned, you're gonna certainly need tyres and fluids so expect to pay another £300 on top of whatever you pay for it.
Maybe mention that and see if a slightly better deal can be made.
Waterhouse
Re: 1998 fazer 600
« Reply #8 on: 22 August 2017, 07:49:57 am »
Cheers darrsi I'll message and see if I can get anything knocked off for tyres and a good service
Re: 1998 fazer 600
« Reply #9 on: 22 August 2017, 08:16:36 am »
Look for a smokey start up from cold. You can cause problems with the rubber seals and o rings drying up from lack of use. The smokey start up would be caused by oil leaking past the valve stem seals.
Waterhouse
Re: 1998 fazer 600
« Reply #10 on: 22 August 2017, 10:07:55 am »
Thanks everyone all good advise. I'm going to give him a call today see if I can view it and if we can get price down abit
steve 10562cc
    • - KAWASAKI Z1000
Re: 1998 fazer 600
« Reply #11 on: 22 August 2017, 11:36:01 am »
It sounds too good to be true to me a 3 year old bike averaging less than 600miles a year in it's first 3 years (only new bike I ever owned average more than 600miles a month in it's the first 3 months)  then stored for 16 years?. It's going to cost you about 2k-2.5k to buy and get on the road me I would be looking for a much newer and 15-20000 miles on it with a history.  What ever you decide enjoy your new bike take it easy to start with till you get a bit of experience and treat every other road user as a complete idiot some wont disappoint you.
Re: 1998 fazer 600
« Reply #12 on: 22 August 2017, 12:51:07 pm »
Could be many genuine reasons why though, it may have been bought as a summer toy, or a commuter in better weather, or they may have just simply thought biking was not for them, especially if they already owned a car?
Waterhouse
Re: 1998 fazer 600
« Reply #13 on: 22 August 2017, 01:38:56 pm »
Well according to the guy selling it it's one former owner. Who was a farmer. Bought it used it abit then put it in his barn and left it apart from that I don't know much more about it
Waterhouse
Re: 1998 fazer 600
« Reply #14 on: 22 August 2017, 01:40:13 pm »
Original description.
Absolutely outstanding
Time warp
1 owner
[/size]One thousand seven hundred and thirty five miles[/b]
[/size]A premium owned genuine barn find[/b]
[/size]1 farmer owner purchased new on 03/08/1998 from Yamaha main dealer[/b]
[/size]Unused for 16 / 17 years[/b]
[/size]New battery and starts first touch of the button[/b]
[/size]Sounds ultra sweet and as it should[/b]
[/size]Beautiful red livery[/b]
[/size]Original tyres and the whole bike is stock / original / genuine[/b]
[/size]These were fabulous bikes and many sold bit find another like this[/b]
Bretty
Re: 1998 fazer 600
« Reply #15 on: 22 August 2017, 02:19:21 pm »
I can't see the photos?! and I'm curious about what it looks like now.
Waterhouse
Re: 1998 fazer 600
« Reply #16 on: 22 August 2017, 03:59:32 pm »
I tried to post a pic I can't seem to figure out how
Bretty
Re: 1998 fazer 600
« Reply #18 on: 22 August 2017, 05:16:52 pm »
Wow! That's probably worth £2k... to someone that wants a brand new old Fazer.
The last bike I had was an immaculate 2001 Bandit with only 1000 miles on the clock... I sold it because I never wanted to use it, ride it or leave it in the rain, get it dirty or leave it parked anywhere. The guy I sold it to just couldn't get his head around why I was selling it.
Waterhouse
Re: 1998 fazer 600
« Reply #19 on: 22 August 2017, 05:19:51 pm »
I've spoke to the guy and managed to wangle a couple of hundred quid off asking price so all been well I should have a new ( well almost new old ) fazer soon
Freck
    • - Triumph Daytona 955, BMW R9T
Re: 1998 fazer 600
« Reply #20 on: 22 August 2017, 06:20:56 pm »
Congratulations mate, I'm sure you'll enjoy your new bike :tl:
YamFazFan
Re: 1998 fazer 600
« Reply #21 on: 22 August 2017, 07:14:42 pm »
The tax disc in the pics expired 31/5/05, so possibly last ran 12 years ago and not 16/17 years.
Great looking bike :)
Waterhouse
Re: 1998 fazer 600
« Reply #22 on: 22 August 2017, 08:05:07 pm »
Well spotted. Maybe just used very little in its early years and then stored after 05
Tefer
    • - FZS1000 2003
Re: 1998 fazer 600
« Reply #23 on: 23 August 2017, 08:39:59 am »
No mileage data on the Vehicle Smart app.
Its a good looking bike and like folk have said should serve you well if you get new rubber and a decent service.
