Have you still got the box eye left hand foot peg? If so I would like it please.
Another question, the passangers footpegs, from what year are? I have a Wingrack2 from 01 and my bike is from 99. Incompatible because the pegs are lowered from 01.
I also have the 99's. I need the 01 model. Seems to be identical but they are different. The 01 pegs are longer and lower.
Seems to be ok. To not lose time and money, could you, please, verify if the online data is correct?"Rear pegs lowered 45mm & moved forward 10mm "The quote is for 2000 improvment compared with 1999. No further note about any modification on later models.Probably you can't see the 10mm forward, in my mind is that 10mm are on frame.
Is that an r6 rear shock I see?
Clearly the foxeye ones are longer I put the boxeye ones on top 🙂
