Date: 26-04-24  Time: 11:57 am
Author Topic: Refitting exhaust FZS600  (Read 2728 times)
brockman
« on: 14 March 2017, 07:08:11 pm »
Hey all,
So, I have a used Fazer in my garden that needs the exhaust refitting.  Problem is the engine studs are all shot to hell, and having tried everything to get them out it's looking like removing the engine & drilling them out!!
Apart from the above, the bike is fine - starts and everything.
Having never taken the engine out of a bike before, does anyone have any tips/gotchas before I start?  I've got the Haynes manual, a garage, and a friend with a penchant for fixing up old cars :)  I'm also going to need new gaskets for the head and for the exhaust headers - does anyone know a good place to buy from??
Will post pics as I go, waiting on garage space at the moment though...
Cheers!
    • disorderly punks motovlog
Re: Refitting exhaust FZS600
« Reply #1 on: 14 March 2017, 08:41:28 pm »
exhaust gaskets £4-5 are all over ebay as are the studs £8ish
i have the exact same problem at the moment and while waiting for the new studs i have sprayed wd on studs everyday
have suffered in this area with smaler bikes with easier access so this is going to be an interesting one
make sure you use a anti sieze compound on the new studs
Andy1970
« Reply #2 on: 15 March 2017, 08:49:40 am »
Regarding removing the engine, the Haynes manual states that you need to remove the oil filter. The only piece of additional advice I have is to remove the oil cooler as well. It is possible (just barely) to get the engine out without doing this, but it's a lot more difficult and you risk scratching the frame and damaging the threads on the oil filter mounting. Good luck.
bird
« Reply #3 on: 15 March 2017, 03:42:16 pm »
I had the same problem with 2 studs. heated 'em with a gas burner and was able to unscrew them no prob!
Wookee
« Reply #4 on: 18 March 2017, 02:00:37 pm »
Ditto.
I didn't even bother trying to get any of them off until I had soaked them in Plusgas for a few days then used a blowtorch. Funny enough they all came off dead easily 8)
« Reply #5 on: 18 March 2017, 07:51:15 pm »
good to hear plus gas and blowtorch works as thats my plan (day  4 of soaking)
« Reply #6 on: 20 March 2017, 09:14:30 pm »
ok so nuts were in worse than expected condition no spanner / gator grip / maul grips would work
spliting chisel and lots of time to tap and split nuts only resulted in two broken studs
tommorow will be removing exhaust, moving rad and associated bits and left over studs
in house engineer (Father) will be drilling out broken studs without much issue as long as no more break
« Reply #7 on: 20 March 2017, 10:05:04 pm »
I had a  similar problem when I replaced my down pipes.
I had been soaking the studs in W/D for about 4 days before starting the job.
Two of the stud nuts come out bringing the studs with them, I managed to get 5 other nuts off but one sheared the stud, but as the others were all off I was able to remove the original down pipes.
The sheared stud was one of the centre (ish) studs and although it was sticking out of the head by a bout 6 or 7mm it was almost impossible to get at, I tried moles but once they were snapped into place the was no room to turn them.
I managed to get the broken stud out by using a small 5mm socket (1/4" drive) with a 1/4" to 3/8" adaptor and a short extension bar that allowed me get between the front duplex frame tubes and gently tap the 5 mm socket onto the the stud that was sticking out of the head.
I kept gently tapping the end of the extension bar and it forced the socket over the stud, actually moving the stud material to completely fill the socket then a ratchet on the end of the extension bar and just unscrewed the broken stud, I actually think that the tapping helped break any corrosion that was helping to hold the stud in place.
I never managed to get the broken stud out of the socket but it did the job.
Oh! my apology to darrsi for the re-writing the Gettysburg Address, but I thought it might be helpful.
tommy
« Last Edit: 20 March 2017, 10:11:21 pm by tommyardin »
« Reply #8 on: 21 March 2017, 12:27:50 pm »
CRAP CRAP CRAP CRAP
5 of the 8 studs sheared heads got to come off now - was amazed how easy they snapped
tried all the tricks heat/flash freeze tap in with hammer to break seal - nothing worked
really didnt want to have to do head strip
and its harder on this than my 82 gsx1100
i knew i should have bought a bike lift
« Reply #9 on: 21 March 2017, 12:57:17 pm »
I know that my bike at 19 years old has over the last 17 years has only ever seen dry roads but stuff still gets rusty, last year I soaked my studs for about 3 months, every time I went out on it and came back I used a syringe with a long blunt needle to get right in and behind the collar I did it whilst still hot and then again when cold. I used something called Kroil which is used for cleaning and maintaining guns and is so called because it is a Kreeping oil (creeping )
They came off ok, but not sure if it has more to do with them being in good condition or if the oil used or the length of time soaking which was the biggest factor but I would recomend getting a syringe for targeted oiling and to do it for longer.
« Last Edit: 21 March 2017, 12:59:53 pm by fazersharp »
vinnyb
« Reply #10 on: 29 March 2017, 08:43:13 am »
Just read this feature about penetrating oil and it seems that a 50/50 mix of acetone and ATF is the best thing to use. Anyone on here tried it?
  Recently an article was passed along to me from Machinist Workshop Magazine.
 They tested some commercially available penetrating oils on a group of nuts & bolts they had scientifically rusted to a uniform degree in a salt water solution.
 The fasteners were treated with a variety of commercially available penetrants and the measured torque required to loosen them was recorded.
 The break out torque required for:
 Nothing =                                  516 ft. lbs.
 WD-40  =                                  238 ft. lbs.
 PB Blaster =                               214 ft. lbs.
 Liquid Wrench =                          127 ft. lbs.
 Kano Kroil =                                106 ft. lbs.
 50/50 blend of ATF and Acetone =   50 ft. lbs.
edit:
It was pointed out that this was a topic a few months ago, so I read through that thread and did notice someone also recommended GM 1052627 heat valve/EGR lube and I have personally used a similar Mopar EGR product for years that works very well but it is definitly more costly then used ATF and Acetone.
And a final note on shop safety and penetrating fluids:
 I was spraying some exhaust bolts on an engine that wasn't running but was warm, when the penetrant hit the bolts it evaporated a bit. The fumes drifted my way and even though I was wearing safety glasses I got some residue in one eye. Flushed the eye for about 20 mins, it remained blurry and irritated so I headed to the emergency room.
 Brought the can along and the doctor about feel over when he read all the solvents that were in it, long story short, 3 hour eye flush on some hospital machine to get the ph normal in my eye socket.
« Reply #11 on: 29 March 2017, 10:25:07 am »
Yes I read the same test last year which lead me to find some Kano Kroil =106 ft. lbs. I just called called it Kroil in my other post.
It is very thin and smells a little acetone/ nampher -- ish - menthol sort of.
vinnyb
« Reply #12 on: 29 March 2017, 10:33:46 am »
 It might be worth raiding the wife's make up box :)  I've got some ATF. Failing that where did you get the Kroil from?
« Last Edit: 29 March 2017, 10:46:42 am by vinnyb »
vinnyb
« Reply #13 on: 29 March 2017, 10:53:09 am »
 Just looked on Ebay and Amazon :eek  They're 'avin' a larf aren't they?
« Reply #14 on: 29 March 2017, 01:44:30 pm »
I paid £21 with post for mine from a Gun shop gun peeps seem to be the only people who use it in this country - its an american product, it was Livens LTD give them a ring as I dont see it on the website.
Just found it here  http://www.mooreleather.co.uk/accessories/kroil but its not easy to find in this country.
I though £21 was better than snapped studs and I can use it on other stuff too.
vinnyb
« Reply #15 on: 29 March 2017, 10:45:08 pm »
That's not so bad, they wanted twice that just to ship it on amazon. Still thinking I may give the acetone/ATF mix a try when I come to take the pipes off. Dunno yet.
« Reply #16 on: 29 March 2017, 11:38:30 pm »
checked out the atf and acetone on youtube
might give it a try sometime - got atf acetone cant be that much
and if it stops me ever having to drill a head again then its worth a try
crickleymal
« Reply #17 on: 29 March 2017, 11:40:00 pm »
Does it matter what variety of ATF you use? Semi synth, dead dino, fully synth?
Malc
Old enough to know better.
« Reply #18 on: 30 March 2017, 01:34:43 am »
well lets be honest we are bikers therefore unlikely to have ATF laying around - so any we can get out hands on free will be a good start
a quick search of the stuff in the video has friction modifiers and all sorts so it surely is some sort of synthetic to me
crickleymal
« Reply #19 on: 30 March 2017, 11:04:50 am »
Couldn't you sleep? I thought I was a bit of a night owl but posting at 1:34am is beyond me.
Malc
