Hi guys Been having a little problem with my clutch recently for about a month and a half/2 months.Every so often the clutch becomes really spongy for a few moments but then will go back to normal, it's very temperamental and I was wondering if anyone could give me any ideas of what could be causing it?I don't mind having to buy a new clutch as springs and plates ain't that overpriced, and I already have a new clutch cable waiting Hope you guys can help as always Thanks
There has been some big discussions on here about tooth numbers and the effect on RPM at different speeds and also something about the same link hitting the same cog more often with certain front and rear tooth amounts.Have a search on here for it.When I do mine I have decides to go with standard extra acceleration would be good but there are times when I look for 7th gear.I would be good to take some side by side pictures of your old and new sprocket for wear comparison.
So how many miles has the sprocket had.Be interesting to see a pic of the new one next to the old
Im no engineer but at 10k and physically looking at the old next to new I would say that it did not need changing.I last looked at mine 2000k ago and it looked ok to me and that was at 18k.
Quote from: fazersharp on 01 February 2017, 01:25:37 pmIm no engineer but at 10k and physically looking at the old next to new I would say that it did not need changing.I last looked at mine 2000k ago and it looked ok to me and that was at 18k.Your probably right Sharpie, I guess it all depends on how you maintain your chain, I'm a bit anal when it comes to looking after the chain and lubing it.I use Motul spray chain lube, it sticks well and does not fly off excessively making a mess of the back wheel.It's due a clean and lube now so it will get done when the sprocket goes on, as stated earlier I was going to put on the new Renthal 15T, But thinking about your comments with regard to the old one think I will put the 16T back on as it does probably does have 3 or 4K left in it. Cheers Sharpie
See in my picture below your cables nipple gets hooked onto the tab which pulls up which turns the round thing with what looks like a tiny ball baring which then rises up/out to push on the clutch rod. There is a spring where it says spring whos job is to pull the arm back down and your leaver back out. The picture is what a clean cover looks like but the whole area can get jam packed with gunge-dead birds -grit so much so that it affects the clutch.When you take the cover off you will destroy a thin gasket but there is no need to fit a new one, but even the very thin gasket removal may mean that you will need to adjust the clutch after.When I did mine I took off the cable and hung it up and sprayed loads of parafin (think I used parafin )down and cleaned it followed by air to dry it followed by ACF 50 lube
Yes that plate is supposed to be a sound proofing/damping thing that they did away with on later models.Yes there is indeed a second clutch ajuster on the outside of the sprok cover its part of the gubbins that the spring attaches to.There is some very useful info on here somewhere try this and the pdf http://foc-u.co.uk/index.php/topic,17488.msg201488.html#msg201488There is a lock nut you need a long socket for and then a screwdriver, never done myself - never needed to
