The air gap is achieved without the springs in the forks so the dimensions of the spring don't figure in the mystery.
More than likely they weren't fully drained. I left mine hanging overnight and still had to pump them several more times in the morning to get all the oil out. Even then they didn't quite take the full specified amount of oil. If I were you I'd take them off again and get the air gap right.I assume you followed the correct procedure to bleed the air from the forks, particularly step 98. After filling the front fork leg, slowly stroke the damper rod up and down (at least ten times) to distribute the fork oil.Be sure to stroke the damper rod slowly because the fork oil may spurt out.9. Slowly stroke the inner tube up and down to distribute the fork oil once more (1 stroke = about 150 mm). Be careful not to stroke the inner tube over 150 mm as this will cause air to enter. If the inner tube is stroke more than 150 mm, repeat steps (10) and (11).10. Before checking the fork oil level, wait ten minutes until the oil has settled and the air bubbles have dispersed.
