Date: 19-04-24  Time: 01:53 am
Author Topic: stuttering fzs 600  (Read 261017 times)
CRH
Re: stuttering fzs 600
« Reply #850 on: 10 November 2012, 08:30:21 pm »
think darrsi might be right you know red ?.....you could easily become the next author of the..second,new,testament of the fazer bible :rolleyes ...ile buy a copy off you? :b .....ps did you read i fixed me stut??
« Last Edit: 10 November 2012, 08:33:58 pm by CRH »
« Reply #851 on: 11 November 2012, 02:26:35 am »
@red98, have you thought of contacting Gareth Gates, he had a bad stutter but seems to have sorted his out okay  :lol
cnw180
« Reply #852 on: 11 November 2012, 04:13:33 pm »
I will try the filter back in at the weekend and let you know how I get on.
I just had a thought though. A friend checked the bike out for me a few weeks ago and commented that 1 cylinder was running hotter than the others (down pipe was noticeably hotter from startup). The other three cylinders were running a little rich(petrol smell) I will check the plugs at the weekend to to confirm this. Anyway a lean mixture would get even leaner with a new filter, so I wonder if one cylinder is too lean at high rpm and is causing the stuttering?
 assume a carb balance may be the simple answer as in the long term, I cant simply stick the old, clogged filter back in, to force the bike to run rich.
Does this sound plausible though??
ummmmmm .....not sure about that  ;) ......start by swaping the filter...i dont think thats the problem but once swaped you can forget about it  :) .....balancing the carbs is always a good thing  :D  do you know when it was last done ?  :)
.....well, checked the plugs and ht leads, bit of wd40 applied. Left New air filter in place as I noticed the rubber cover over the airfilter casing had snagged over the air intake, possibly restricting the airflow. Assuming the engine needs a huge "gulp" of air when the throttle opens, this may have been an issue. Will test ride before putting old filter back in.
Bike fired up fine, needed a bit of choke, normally doesnt! Idling ok, just a tiny bit lumpy...
Will post back later!!
Well I put the original filter back in and the bike is now fine, stutter gone!  :lol  Checked the two filters while out and the new one is a tiny bit smaller. Noticed the box it cam in had 98/99 for the year. Wonder in the filter is different on the 2000 model then????
Anyway, bike running nicely, carbs do need checking for balance, but power all back now!!
 :D
« Last Edit: 11 November 2012, 04:14:29 pm by cnw180 »
« Reply #853 on: 11 November 2012, 04:21:50 pm »
Was the new filter a Hi-Flo one by any chance?
cnw180
« Reply #854 on: 11 November 2012, 04:33:02 pm »
Was an aftermarket one, apparently standard, but who knows with pattern parts. The original filter had a gauze/mesh cover, the replacement had a metal sleave round the outside, with holes in it....?
« Reply #855 on: 11 November 2012, 05:15:29 pm »
I had one like that, and i think it was also red98 too, and i never really thought too much about it until i swapped it for the K&N filter about how ill fitting it was.
The K&N made a really tight, fitted seal whereas the other one probably had about 5mm play around it.
I doubt very much at all that it's anything to do with the year of the bike.
I would seriously recommend getting a K&N filter though, you can really notice the bike breathing better, and you only need to buy the one as they're guaranteed for a million miles, and you don't even need to clean it for the first 50,000 miles!
£30 on Ebay.
cnw180
« Reply #856 on: 11 November 2012, 05:49:11 pm »
£30 on Ebay.
Sounds like a plan!
    • - FZS600,CB400/4,X7,CB250
« Reply #857 on: 11 November 2012, 07:10:14 pm »
£30 on Ebay.
yes thats right darrsi....lousy fit but did`nt notice untill i fitter the k+n......well worth the £30...best filter by miles  :D :D :D :D
« Reply #858 on: 11 November 2012, 07:15:01 pm »
ummmmmmmmmmm gareth gates.......................now iam sure you dont want me to start singing  :eek :eek :eek :eek :eek that will be worse than the stutter  :rollin :rollin :rollin :rollin :rollin :rollin
well swmbo`s car back together and working but will need a new thermostat housing  :\ :\ :\ just needs the o ring seal but cant buy them on their own  :\  always something to spend your money on  ;)
« Reply #859 on: 11 November 2012, 07:19:11 pm »
I really should apply for a job in the K&N marketing department........  :lol
« Reply #860 on: 11 November 2012, 08:50:35 pm »
 :rollin :rollin :rollin :rollin :rollin they are a good filter,been going for years  :D
Andy FZS
« Reply #861 on: 11 November 2012, 09:08:46 pm »
Just ordered one as I didn't change the filter earlier in the year when I changed oil and plugs. The last K&N filter I ordered was 4 off the little cone filters for my Honda 400Four in the mid 80's.
Andy
« Reply #862 on: 12 November 2012, 02:52:19 pm »
Andy
those were the days......got them fitted to my x7,not the same as standard as you do away with the air box and increse the jet size.....together with the microns it lifts the front wheel in 2nd just using the throttle  :eek :eek
Andy FZS
« Reply #863 on: 12 November 2012, 04:24:10 pm »
I remember being pillion on an X7 once heading towards a humpback bridge followed by a tight right hander :\  I was punching the pilot to slow down but all I could hear was his laughing :'(  Anyway we were home before the pursuing 250LC and CBX550. Those were the days and I don't miss them at all..............away camping every weekend straight from the pub into the tent and then back in the pub, no why would i miss it :\
Andy
« Reply #864 on: 12 November 2012, 09:15:44 pm »
Andy
ah yes.........................happy days  :) :) :) :)
« Reply #865 on: 24 December 2012, 09:09:44 am »
hhhhhhhhhappy   ccccccccchristmas    eeeeeeeeeeveryone..............................and hopefully a smooooooth new year,thank you all for your comments and laughs..............the stuttering lord
Andy FZS
« Reply #866 on: 24 December 2012, 09:25:12 am »
Happy Christmas to you, how's the bike?
Andy
Sent from my GT-N8010 using Tapatalk 2
« Reply #867 on: 24 December 2012, 06:16:39 pm »
Andy
not done anything with it since my last update............still finishing the bathroom  :eek :eek :eek :eek ....nice tidy garage now with a new roof some new tools and a nice new  roll cabinet to put them in  :D :D :D ,iam off work now until the 2nd jan so should be able to find time to tinker.....if i remember i was going to look at the fuel pump next  ;)
Andy FZS
« Reply #868 on: 24 December 2012, 10:38:55 pm »
I think you were quoting something about newton and laws of physics if I remember correctly^-^
Andy
« Reply #869 on: 26 December 2012, 09:32:04 am »
Andy
ah yes..............its all coming back to me now,thanks for the reminder  :)
    • - FZS600 00-01
« Reply #870 on: 23 January 2013, 12:30:52 pm »
Hey red, any more news or has swmbo been keeping you busy?
« Reply #871 on: 23 January 2013, 01:16:03 pm »
swmbo`s very good at keeping me busy  :rolleyes :rolleyes :rolleyes ......still not finished the bathroom,very close though.....bikes been covered up in the garage since my last post many moons ago,weathers looks like its getting better for this weekend so might get out there and put the origanal carbs back on and correct the shim c**k up .......will update at weekend........my monies on the fuel pump now so will bypass this with a peice of straight tube and see what happens  ;)
« Reply #872 on: 27 January 2013, 04:58:31 pm »
nice day too fettle in the garage  :D  uncovered the 600 and removed the carbs in readyness to fit the originals,now iam a GP HERO  :rollin :rollin  its very easy and i completed the job in less than an hour,i borrowed a few bits and peices from the old carbs and next job is to refit them,sort out the shims and by-pass the fuel pump,not a great deal done today but its a start  ;)
« Reply #873 on: 05 February 2013, 08:03:07 pm »
seeing all thoes 600s at the london foccer meet has got me motavated again.....spent half an hour tonight putting the original carbs back together sliders glide smoothly and settle with a reasuring knock......iam now happy that the carbs are not causing the stutter  :) ........all my hopes are on the fuel pump and i dont know why i didnt check it in the early days of "stutter solution saga"..........so a question for you all....anyone had any problems with fuel pumps ?......bikes a 1998 , done 40000 miles and been well looked after ;)
    • - FZS600 00-01
« Reply #874 on: 05 February 2013, 10:11:54 pm »
I'm pretty sure bozboz had some issues with his fuel pump recently. They aren't overly expensive to replace though are they?
