This has been bugging me since i got the bike......My handle bars seem to sit a bit squint, just wondering if anyone else's does this or 8f there's a solution.1st pic is how they sit.2nd pic is how I think they should sit.It's notacible as when I try to ride with them straight the bike veers of route, My tyre seems straight as the wear indication is even but I'm compensating as I'm riding.
Just loosen the pinch bolts hold the wheel and bars straight and nip the bolts up. Shouldn't take long
Easiest way is to loosen all the pinch bolts and then, with the wheel straight, push down sharply on the bars 2 or 3 times. That will re-align the forks and the bars. Then, without disturbing anything, tighten the pinch bolts. Worked on mine.
DO not loosen them to much, but you should really loosen the axle also.Other option with the pinch bolts and axle loosend is to put the wheel between your legs, catch the bars and pull the right one forward a little.What you are doing is twisting the centre stem to realign the forks and that nutt is tight (110Nm tight)If all is straight as you say, most likely if the head race bearing were ever greased the centre stem bolts were tightened with the forks misaligned or before the forks legs were put back in.I usually put the axle and fork legs in, tighten the lower pinch bolts before tightening the centre stem if I am doing anything with the head raceThis prevents the top yolk going out of alignment when tightening the steering stem nut.
I think the bikes foced, ill take it off your hands for £10 and a half sucked worthers original
My grandma believed gargling warm horse piss was a good cure for anything..................
