Plenty of silicone blanking caps on eBay. Anyone know the internal diameter required for the airbox and carb hose?
Hi Tefer,I made a note in my little black book when PieEater posted the part number info early last year, just haven't got around to removing my AIS yet.Caps are #3 16G-13569-00(Plug blind) the clips to go with them are #4 90467-10039(Clip).Just use some high temp silicon on the spigots before sliding the caps on.Hope this helps.
Does anyone have the diameter for the airbox plug or a part number? I got the smaller ones for the Carb 4 intake.
Quote from: Tefer on 02 January 2017, 03:11:12 pmDoes anyone have the diameter for the airbox plug or a part number? I got the smaller ones for the Carb 4 intake.I used a cap from one of Mrs PieEater's cosmetic bottles for mine and I let AndyW have the cap from my visor cleaner spray bottle to do his, just used some silicone on the inside to make sure the fit was airtight and some gaffer tape on the outside to make sure it stayed in place, both have been fine since. So bottom line is you'll probably have something suitable knocking around at home without having to buy anything special.
