Date: 23-04-24  Time: 12:09 pm
Author Topic: Speedo stopped  (Read 3252 times)
kevinuk1
      FZ6 S2 07-09
Speedo stopped
« on: 31 October 2014, 03:54:01 pm »
Can anyone give me an idea of any quick fault finding tips on how to diagnose why my speedo has stopped, speed and mileage/trip not working
Am ok with electrics/electronics just not sure exactly where to start
Any help much appreciated, thanks in advance
Re: Speedo stopped
« Reply #1 on: 31 October 2014, 04:35:05 pm »
Had the front wheel off at all recently?
kevinuk1
      FZ6 S2 07-09
Re: Speedo stopped
« Reply #2 on: 31 October 2014, 05:27:14 pm »
No, been using bike every day just suddenly stopped working
mickvp
Re: Speedo stopped
« Reply #3 on: 31 October 2014, 05:37:11 pm »
first port of call is to pop the wheel off and have a look at the lugs on the speedo drive doodah. they are prone to breaking, althoug its normally in the process of removing/refitting a wheel.
kevinuk1
      FZ6 S2 07-09
Re: Speedo stopped
« Reply #4 on: 31 October 2014, 06:42:09 pm »
Are there any lugs ? Is that if you have a drive cable , thought there is a sensor
limax2
  • Creep.
Re: Speedo stopped
« Reply #5 on: 31 October 2014, 07:01:03 pm »
Yes there are lugs on the "doodah" thing that revolves with the wheel and the lugs engage in two slots in the wheel. The sensor gets the signal from it as it revolves. If the lugs break then no signal.
kevinuk1
      FZ6 S2 07-09
Re: Speedo stopped
« Reply #6 on: 31 October 2014, 07:03:20 pm »
Oh ok I will check tomorrow thanks
limax2
  • Creep.
Re: Speedo stopped
« Reply #7 on: 31 October 2014, 07:09:04 pm »
Just be careful taking the wheel out and especially putting it all back as it is easy to break the lugs during that operation. Good luck.
Deefer666
  • Loves to hit stuff with hammers!
    • - FJ1200
    • Motorcycle Republic
Re: Speedo stopped
« Reply #8 on: 03 November 2014, 10:30:28 pm »
and check the wire coming off the sensor to make sure it hasn't been caught by the disc, although as mentioned before my money is on the lugs snapping off the ceramic drive dog inside the sensor.
Vys
    • - Past: FZS600, FZ6, TDM900
Re: Speedo stopped
« Reply #9 on: 04 November 2014, 12:55:56 am »
Hi,
i had same problem recently (+ a few more), so if your tachometer works fine and doesnt jump to 3k or 4k revs constantly then it'll be Rotor sensor (same plastic/magnet thingy on the wheel as it was said in previous posts) or might be wires damaged somewhere between speed sensor to gauges unit.
If so then youre looking for Rotor Sensor Part No  5VU-2517G-00-00
also attached picture of it...
Good luck
Deefer666
    • - FJ1200
Re: Speedo stopped
« Reply #10 on: 04 November 2014, 07:44:40 am »
from memory they are about £15 from Yamaha
mtread
Re: Speedo stopped
« Reply #11 on: 04 November 2014, 11:52:17 am »
and notice that the replacement doodah is plastic rather than ceramic, so much less likely to break.
O, and make sure you put plenty of grease on it when you fit, otherwise it makes a hell of a whining noise, and you then have to take it out and do it again, as I know ...............
« Last Edit: 04 November 2014, 11:54:53 am by mtread »
kevinuk1
      FZ6 S2 07-09
Re: Speedo stopped
« Reply #12 on: 04 November 2014, 12:18:02 pm »
Thanks to all those who have passed on info/help etc..... unfortunately I have not been able to investigate it myself due to work commitments so its now with a local repairer.
Do appreciate feedback, I will report back with what was wrong hopefully later today to assist anyone else in the future. Its my main transport so missing it already  :(
kevinuk1
      FZ6 S2 07-09
Re: Speedo stopped - Update
« Reply #13 on: 04 November 2014, 10:29:46 pm »
Guess what you guys were spot on  ;) it had broken into pieces...... new one ordered and will be fitted on Thursday.
Just a small point which may be relevant for others, prior to my speedo stopping I had a very slight squeek from the front wheel which could only be heard when coasting. this may be a coincidence but might have been a tell tale sign that it was about to break?
Anyhow thanks for all your feedback
Kevin
« Reply #14 on: 05 November 2014, 10:43:54 am »
Kevin
Have you checked behind your radiator for mice?  :b
Hedgetrimmer
Re: Speedo stopped
« Reply #15 on: 05 November 2014, 11:00:40 am »
This all got far too technical for me  :lol
papercutout
Re: Speedo stopped
« Reply #16 on: 05 November 2014, 03:00:26 pm »
Just for reference, in case anyone else gets this problem and it ISN'T the sensor - my speedo stopped working, I took the gauges apart and there was corrosion on the board. I cleaned it up with electrical cleaner and it worked again.
kevinuk1
      FZ6 S2 07-09
Re: Speedo stopped
« Reply #17 on: 06 November 2014, 06:09:25 pm »
All now sorted for £40 very happy with that :)
