Date:
25-04-24
Time:
13:19 pm
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Forum
Basics
FAQ
Tips and Tricks
SMF's help
About
Links
Articles
Fazer1000/FZ1
FZ8
FZ6
FZS600
For any bike
Misc
Media
Downloads
Fazer 1000/FZ1 corner
Switch or motor?
« previous
next »
Print
Pages: [
Author
Topic: Switch or motor? (Read 5248 times)
ghostbiker
Muck Spreader
GP Hero
Main bike:
- GSX600F Katana
Switch or motor?
on:
29 June 2011, 05:17:07 pm »
I noticed shortly affter the winter if i was in realy heavy traffic and couldnt be arsed to filter (happens now and then :P ) i got the red temp light pop on, went off again as soon as i got moving or turned engine off.
Also noticed it 3 or 4 times now when on charity runs (only this year, was fine last year) that again in slow or staionary traffic the red warning lamp comes on.
So today i went out a rode slowly round town for 15 mins or so to try to make it happen, sure enough affter a while the red light came on, and cleared as soon as i crept the speed back up.
so tried again and got the red light on, this time i got off the bike and checked the fan.... No fan on !!!
now im 90% sure the fan should be on long before it gets hot enough for the warning light. so i must have a problem.
In my VERY limited electrical knowlage it would seem to me there would be a switch to turn the fan on once it gets to temp "A" and a 2nd or maybe the first is variable to set the light on when the temp hits "B"
so either the switch is faulty or the fan motor itself had died.
but how can i find out what one it is?
PS sadly i doubt i will get many replys as most ppl dont even know this board is running yet lol. DAMN YOU YUKU!!! :P
Logged
Loopyjasper
Cager in Training
Main bike:
FZ1 Naked Gen2
Re: Switch or motor?
Reply #1 on:
29 June 2011, 08:04:16 pm »
The fans should come on automatically when the temp reaches 100 degrees and go off again when it drops below 94 or 95. There is a relay located under the seat which controls this. Don't know where the temp sensor is though, sorry. I have actually fitted a flick switch to turn the fans on manually as I feel that 100 degrees is too late to be bringing the fans on. As i live in a hot country, I turn the fans on when I am in town by wiring direct from a switch to the relay an in effect making the contact. You could test the relay by simply bridging between the terminals to see if the fans come on. If they work then the problem may be with the sensor if not then the relay will be at fault.
The relay is small and black with a white/clear connector coming out of the main loom. It is located behind the battery and directly under the front seat release mechanism (not key on the side but where the seat clips into). The white/clear connector has four wires - Red, Brown with Green stripe, Red with White stripe and Grey. The Grey wire is much smaller and this is the one you want. If you touch a wire between where the small grey wire is connected and the battery NEGATIVE terminal (ie earthing the connection) with the ignition on the fans should come on. This is a volt-free contact so no chance of shock! As I said above, if the fans run then the problem may well be with the temp sensor.
Also setting at what temp the fan comes on is not adjustable without adding more complicated electronics.
The link I have included below is what I used to install my manual running switch which has some pictures and may be of use to you. It is for an older model FZ1 but the principle is the same.
http://www.angelfire.com/ia/z/FZ1fanswitch.htm
Hope this is of use and good luck.
Logged
ghostbiker
Muck Spreader
GP Hero
Main bike:
- GSX600F Katana
Reply #2 on:
29 June 2011, 08:32:05 pm »
Spot on, i will take a look tomorrow
I did think about fitting a switch, but to be honest its rare i sit in traffic and even rarer that we get warm weather in the UK lol
Logged
ghostbiker
Muck Spreader
GP Hero
Main bike:
- GSX600F Katana
Reply #3 on:
30 June 2011, 11:26:36 am »
Hmm well just taken a quick look (wish my damn haynes manual would arrive
i think i found the 4 wire relay you refered to but its not exactly where you said and its not the same wire colours lol.
i think this is the relay
the 4 wires
2 wires seem slightly thinner (but not by much)
Logged
The Male Whale
GP Hero
Main bike:
- 1300 Pan European/ZZR 1400
Reply #4 on:
01 July 2011, 07:51:52 am »
Why not just change the fuse.....?
It's in the FUSE BOX by the way.
"When walking down the road and hearing hoofbeats, expect to see horses and not zebra's when you turn...."
On the Gas!
Logged
On the Gas!
ghostbiker
Muck Spreader
GP Hero
Main bike:
- GSX600F Katana
Reply #5 on:
01 July 2011, 09:21:38 am »
Quote from: The Male Whale on 01 July 2011, 07:51:52 am
Umm because it would be pointless as they are fine?
I pulled all fuse's before i started the thread and tested with a meter. (tested all of them as untill the haynes manual arrives i dont know which one if any would effect the fan)
Also checked conections on what looks like the temp sender and the connections on the fan, both clean and looked fine.
since posting i checked the conections on everything that unplugs under the seat and side panels... well may as well do them all untill i know what one i need lol
Logged
Loopyjasper
Cager in Training
Main bike:
FZ1 Naked Gen2
Reply #6 on:
01 July 2011, 11:40:33 am »
Sorry, I just realised that you have a Gen1 FZ and I have a Gen2 - doh! I am afraid that I have no idea where the connections would be on your bike, probably best to wait for the manual unless somebody else can shine a bit of light on the subject.
Another possible option would be to go onto the website of a genuine Yamaha dealer as a lot of them will have a microfiche type program which has exploded views of every system on your bike ie fuel, electrical, suspension, braking etc so that you can get the part numbers for ordereing. One of these views will show the fan relay and its location. I would guess it may be labelled 'Cooling Fan Relay' possibly. Just used one of these to order a new plastic instrument cover but it is a Spanish dealer so of no use to you. I have however come across the same thing on British and American websites so it is just a case of looking.
Good Luck
Logged
FZ_Rich
Cager in Training
Main bike:
Reply #7 on:
01 July 2011, 01:38:48 pm »
to test the fan attatch a fused positive feed from a battery to the blue wire and earth the black wire (lift the tank to get to fan wires)..see if she spins
to test the relay take off left hand side panel and remove the relay (note what colour wire goes where) using your leads straight from the battery again put the fused positive to the Brown terminal and the negative to the Green/Black terminal at this point the relay should click and connect the other two terminals inside (brown and blue) use a continuaty tester to check this for 100%
the thermo unit (temp sensor) should make the temp warning led come on for a few seconds when you first turn the ignition on and the go off letting you know that alls well with the circuit.
If you have a fault with the thermo unit let me know and I'll post what my manual says about that (quite lengthy that bit!)
Logged
Life is like a bunch of chocolates - you never know what yer gonna get. . . unless you read the card
ghostbiker
Muck Spreader
GP Hero
Main bike:
- GSX600F Katana
Reply #8 on:
01 July 2011, 02:03:22 pm »
Thx a lot guys, Manual finaly arrived today (2 weeks to get here /sigh)
Ran the tests (pretty much as FZ-rich said) from the manual and its a faulty relay
will track one down this PM and replace.
Just as an aside, for part numbers and descriptions i offten use
http://www.cmsnl.com/
they have a lot of bikes listed and offten can help looking at how something is put together. the part numbers have allways been right so far. although i havent actualy ordered from them i just take the part number to my stealer.
Logged
thecert
About as funny as a
wasp in your helmet.
GP Hero
Now on a new ride but still love the thou'
Main bike:
- Triumph T120
Reply #9 on:
13 July 2011, 10:21:07 am »
Hi ghostbiker, I see that your manual you have been waiting for has arrived but have you seen the page to which I have sent you a link to? If not I think you will find it very uesfull there is reference to the fan that you are having problems with plus a shed load of other stuff.
http://www.cartestsoftware.com/fz1/
Logged
When the going get's tough the tough get going.
Print
Pages: [
« previous
next »
Switch or motor?
SMF 2.0.18
SMF © 2011
Simple Machines
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
