Date: 25-04-24  Time: 01:37 am
Author Topic: Bearing Designations for Gen 1 Fazer 1000  (Read 31006 times)
GringoRojo
  • Otter baiting foccer
    FOC-U Dancing on Ice Champion 2010
    Aug 08
    Oct 08
    Sept 09
  • a Doonhamer in exile
    • - Triumph Tiger800XC
    • a two wheeled charity ride without engines
« on: 08 November 2010, 02:21:21 am »
Originally posted by MikeGTX, alias Falcon 269
For anyone who's looking to replace the bearings on their Fazer 1000, the following is a list of the bearing types and sizes you'll need.
While you can get most of these from bearing factors all over the UK, I strongly recommend you contact Marc at BikeBearings UK (http://www.bikebearings.co.uk/) as this chart would not have been possible without a great deal of research and cooperation on his part. His prices are very competitive and he deserves our trade, I believe.
Marc's website lists all the necessary bearings in specific kits for front, rear and the rear sprocket carrier. He also offers taper roller bearing sets for the steering head.
I hope you find this useful and that it saves you time and expense buying replacement bearings at inflated Yamaha dealer prices.
Mike
Front Wheel Bearings & Seals BikeBearings UK kit YA004
2 x 60/22 2RS sealed race ball bearings
2 x 28mm x 44mm x 7mm seals
Rear Wheel Bearings & Seal BikeBearings UK kit YA001
1 x Koyo or INA sealed needle bearing ref bkm354220-1UU
1 x 60/28 2RS sealed race ball bearing
1 x 35mm x 52mm x 8mm seal
Sprocket Carrier Bearing & Seal BikeBearings UK kit YA002
1 x Koyo 62/28 2RS sealed race ball bearing
1 x 40mm x 58mm x 7mm seal
Tapered Steering Head Bearings BikeBearings UK kit YA003
1 x Koyo 32005JR taper roller bearing - internal diameter 25mm
1 x Koyo 32006JRRS taper roller bearing with bonded seal - internal diameter 30mm
Suspension linkage bearings, collars & seals no kit name.
They're not listed but Marc knows which ones are required. Get in touch and tell him what you need.
2 x 93317-31771-00 BEARING (HMK1720C/2A)
4 x 93317-21746-00 BEARING (HMK 1715C/2A)
He can't, though, help you with the oil seals and spacer bushes. You will need genuine Yamaha parts. That said, you can re-use the seals if they're in reasonable condition and you remove them carefully.
Part numbers are:
8 x 93109-17071-00 OIL SEAL
1 x 90387-102R4-00 COLLAR (ie spacer bush)
1 x 90387-127W0-00 COLLAR
2 x 90387-126Y1-00 COLLAR
Inner Ring/Collar (this is the collar that goes on the left hand side) INNER RING
1 x 28x35x32mm
If not using bikebearings.co.uk
When it comes to buying the bearings and seals, try to opt for European make rather than Japanese, as they are invariably higher quality.
RHP/SKF are a good bet for the bearings, and BSL (Bearing Service Ltd) are an excellent source in most decent size towns (and wolverhampton).
Try to haggle on the price, as you will probably be quoted full list and it's not uncommon for trade to get discounts of up to 70%
karlo
  • By Fazer I Fly!
    • - Swadlincote, S.Derbys
    • UK Bikers
Re: Bearing Designations for Gen 1 Fazer 1000
« Reply #1 on: 30 June 2012, 09:52:08 am »
Old topic I know but.....
Just ordered a Clutch release bearing numbers on it are:
KOYO 600304 (YAM OE 93306-00315)
Also says SH Japan.
ID 17mm
OD 35mm
Width 10mm
« Last Edit: 30 June 2012, 10:36:50 am by karlo »
nickpeh
« Reply #2 on: 07 November 2015, 07:47:15 am »
Hi guys,  as above the 60/28 2RS should be installed on the right side of rear wheel ? The existing oem bearing seems to be not covered by a seal on the outboard side of the bearing cage , except that the one installed as oil seal on hub. Is it fine to get those that has seal on both sides of the bearing cage on this item? It shouldn't be hindering anything there i supposed? Pls advise. Thank u.
Nick Peh
NorthWestern
« Reply #3 on: 07 November 2015, 06:19:44 pm »
Yeah it goes on right hand side.  My bearings have all had seals both sides, either skf or koyo.
Intentionally left blank
